I’m trying to utilize hybrid rendering but can’t seem to figure it out. When I enable it, hit render and when it finishes, I get the attached result. Am I missing something?
Looks like some issue with a GPU and it stops rendering. What does vray progress window say?
Please try rendering the project again but before hitting the Render button open the V-Ray Frame Buffer (VFB) and click the square icon at its bottom-right corner which opens the progress window.
If the issue is then reproduced, copy the entire log from the progress window, paste it into a text file and send it over at support@chaosgroup.com for investigation.
Additionally, please mention the version of your operating system, full version number of V-Ray and whether the problem occurs only with specific projects.
Kind regards,
Peter
Will do. Thanks!
