I bought VRAY 5 for SKetchup 21 but impossible to make it work. Here is the error message I have:
Can you help me?
Thank you
Fred
Erreur de chargement du fichier /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb
Error: #<Errno::EACCES: Permission denied @ rb_sysopen - /Users/fredericbattle/.ChaosGroup/V-Ray for SketchUp/VRayForSketchUp.log>
/Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/logger:9:in `initialize’
/Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/logger:9:in `open’
/Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/logger:9:in `module:Logger’
/Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/logger:3:in `module:VRay’
/Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/logger:1:in `block in <top (required)>’
/Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/helpers:3:in `eval’
/Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/helpers:3:in `require_crypt’
/Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/helpers:3:in `block in <top (required)>’
/Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:48:in `eval’
/Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:48:in `require_crypt’
/Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:48:in `block in <top (required)>’
/Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/eula.rb:48:in `ensure_accepted’
/Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:36:in `<top (required)>’
/Applications/SketchUp 2021/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `require’
/Applications/SketchUp 2021/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `load’
/Library/Application Support/SketchUp 2021/SketchUp/Plugins/vfs.rb:29:in `register_extension’
/Library/Application Support/SketchUp 2021/SketchUp/Plugins/vfs.rb:29:in `module:VRay’
/Library/Application Support/SketchUp 2021/SketchUp/Plugins/vfs.rb:4:in `<top (required)>’
Thank you for your post.
Could you please follow the instructions from the below file and let me know if you made it to work?
https://ftp.chaosgroup.com/Download/permissions\_mac.pdf
Thank you.
no, it didn’t work. the permissions were already activated…still have the same error message
You can install the previous update 1.5 and it will work while you wait for the hotfix for update 2 that should be released soon:
https://download.chaosgroup.com/down…2021-51006-adv
Or alternatively you can install the nightly build in which the issue is fixed:
