hi…
the new issue i found is when i increase quality of render , revit close without continue render… is there any solution plz
Do you attempt to increase quality at render time? How do you increase it? Can you provide more detailed steps of what you’d done?
when i change resolution value or changing quality from medium to higher
Do you render with Vision or with V-Ray? Can you provide a visual example?
