I can't save the "RGB color" channel the way it is shown in the VFB
Hello. I have a Denoiser render element and I have increased it’s Opacity to 0.8 in the VFB to have my image be partially denoised to avoid the artificial/plastic look of a fully denoised image.
However, when I save a multichannel EXR image with all the render elements via “V-Ray raw image file” or via “Save all image channels to single file” from the VFB, the “RGB color” layer isn’t partially denoised and doesn’t match what I’m seeing in the VFB. Why is that? I have ticked the option “Save VFB color corrections to RGB channel” in the save dialog of “V-Ray raw image file”. The same thing happens when I use the “Save File” option with any image format from within the Common tab of the Render Setup window. Please see below. Interestingly, when I save only the “RGB color” channel directly from the VFB, the image is correctly saved partially denoised.
It seems you’ve already encountered this issue in this thread here. Use the same workaround.
Thanks. I think I got it working now!
