On windows 10 max 2017 vray 3.60.03
I can’t see some setting for example: the warn for non-physical settings and the vrscene export are not available in the menu
They are visible under the Active shade mode. I see you are currently using the Iterative mode.
You mean if I render in prodution mode or iterative mode I can’t remove those warnings on the render image? Why is that? How do I render an animation with V-Ray Rt without seeing warnings on the images?
We won’t print any warnings in the VFB when RT is under production/iterative mode. You can see them only in the V-Ray Log window. There are control options only when running it in Active shade mode.
Ok thanks! I should have noticed… ![]()
