I don´t like this curtains
Hi…my last interior…In the curtain I use a fallof map in refraction, but i don´t like to much…any tip or tuto, please?
sorry for the definition, but only 20 min with vray1,47 and amd 1,300Mhz…well, “only” for my times.
better
maybe better?
I think the curtains are fine, but your cam settings and point of view are looking strange, I think that makes it a bit unreal.
Did you use a high FOV value? maybe you should move your cam a little to the left and lower the FOV, you can make your view wider by increasing your output width.
Thanks Joost Ink :smile:
You are rigth…but I nedd to see the kitchen…I will try
just just to note. i do like the 2nd one better
Looking good! Keep up the good work!
well…I work on the camara FOv…
maybe better?..thanks for help me to get more quality …
best regards
