I don't understand why my picture seems with a colour orange
Hi
I really really really don’t understand the light and the sun in Vray.
I made a lot of tutorials, and even now, with a basic rendering like to put an object on a table, using Rhino Sun, i can’t understand why why why i have two pictures with the light that is so different, and i don’t know why…
I would like to have the light like in the first file called “Forum 5” i join here, and not with that horrible orange colour like i have in the file called “Forum6”…
Can you please help me???
I really don’t know what i did to have this horrible orange rendering.
I must admit that i am seriously think to change my software, to use Artlantis, and not Vray, i really don’t understand this software… Every times i use it, it is a nightmare, even for basic things, and i don’t want to imagine to use it for wwhat i bought it: architectural renderings…
Thanks so much to help me once again…
Well… and i don’t understand this forum too, this is impossible to send attached files that are moire than 2 mega, what i have…
Other thing, the plant should be green , and this is so dark…
Thanks a lot…:frowning:
Marbella, which software are you using Vray inside of? I use it inside of Revit (2021). It took a while to figure out how to use the Revit sun to get the right results in Vray renderings, but I eventually got there. The exposure and white balance settings in Vray are very sensitive so sometimes making only a tiny adjustment might get the results you want. Sometimes I still can’t get the lighting 100% the way I want it with Vray so I save the rendered image and then open it with post-production software like Adobe Photoshop (or Paint.net which is free, but similar) and adjust the lighting and color balance as needed. I also see you are using the CPU setting to produce the rendering. If you have a GPU installed, select CUDA or RTX for better (and faster!) results.
Hi jp_bernier
Thanks so much
I am using Rhino 7 with Vray
