I’m really frustrated by a handful issues with max and vray:
- GPU Denoiser is not working in VFB. (Progressive)
Hardware acceleration on/off leads to nothing, select gpu devices = nothing.
Only Standalone Denoiser is working. Setting “only generate render elements” leads to finished render and after finish it worked on GPU by switching to “show denoiser result channel” and press update. So with active “show denoiser result channel” it leads to stuck on Pass(3). 0%CPU and 0%GPU
All you can do is kill 3dsmax.exe
- VFB is not updating in Progressive Mode
only works when you zoom the image!
Notes:
- This in a administrative cmd does nothing, all cores are used by vray at 100%
set /a CORE_COUNT=%NUMBER_OF_PROCESSORS%-1
setx /M VRAY_NUM_THREADS %CORE_COUNT%
- Also the sys-variable “VRAY_NUM_THREADS” leads, …****TATA****… to nothing!
