Take a look at this scene.
I noticed it happening as I was playing with an ocean sim, where I switched between metres/cms units.
In this scene I deleted all the sim elements to see if it still happened and it appears so.
If you switch to cms it’s fine.
I tested this and found that if the scene units are cms to begin with, then that causes the problem, with no way to fix it.
If the scene is set to metres then switching subsequently is no problem.
UPSIDE DOWN CLOUDS.rar (142 KB)
