I nee help with Cinema 4d Corona renderer
I dont know how to render a higher resolution in cinema 4d with corona renderer. I can change the normal render settings but when i start to render, the veiw is way too zoomed in. I cant seem to find a clear answer, please help
Hi, It sounds like you are referring to IR rendering? If so, this is a known issue. A workaround would be to use a resolution that suits your screen size for test renders and then change the resolution to something higher for the final render. During the final render, you can use the - / + icons to zoom in or out.
