I am rendering A interior …with curtain walls… you can see images
however problem is when i am rendering curtain wall with glass material with no thickness to glass and ( Thin (no refraction)) no i am able to render it with Sunlight in side hall.
But when i am rendering with 10mm thickness to my glass And turning Off ( Thin (no refraction)) i couldn’t able to see sunlight in side hall ..can any one help me what i am do wrong here
i want sunlight in hall ..at the same time i want my glass some thickness TOO…Can any one help me here
Hi Rawalanche
i have done same thing when i use thin with single plane there is no problem…with sun light…as i have shown in image
however when i use two faces (or some thickness ) with no thin on…sun light could not pass through glass…
here what i want is sunlight in hall with some thickness to glass with thin OFF
You are not using the “Caustics (slow)” option, huh?
No coplanar however one with portal and again it is faraway form this glass…No inverted normals
yes i tried it BUT No use…
Can you try reproducing this “bug” in a more simple scene and sharing it? I tried and all kind of glass let sunlight through. Only when caustics are enabled there are some problems.
Ok maru I will
if there is nothing behind your windows, why u even make glass ?
Nothing from inside reflect in them.
You have to take into account your reference is from angle, therefore fresnel makes the specular reflection more prominent.
In real-life, this is coated material. It’s semi-glossy rather rough (vynil/paper/woodchip/etc..) surface, spraypainted with glossy coat (usually Polyurethane in 1 to 3 layers).
So more complex scenario is to do blend material with each having correct reflective curve (or higher IOR for coat in simpler way).
Simplest is to simply rise the fresnel IOR from 1.52 to to something like 2-3.
Juraj I have a question for you about reflections.
How do you make reflections in your renders so clear and sharp?
e.x. here https://m1.behance.net/rendition/modules/66515785/hd/eddde03d5346f3d71974b71ab3f39cb4.jpg
Is this matter of render settings, render time (in corona) or smth else?
Use portals where ever necessary … it will take care about 50% of it remaining 50% is to cook it some more time..HAHAHA
its Only example
i meant those reflections in exterior glass ![]()
there is no environment map …only white color with 245 i think And EV 5
