I need those example in doc site?
hello
can you guys share all sample scenes in those video example plz, they are fun thanks!
These are the scenes:
Just keep in mind that some scenes use a script to run a render after the simulation has stopped or to start simulators one after another. You can disable this from the checkbox “Use Script” in Simulation rollout menu. Also, the first thing you should check before simulation is the Input/Output cache paths.
Cheerz!
Scenes.zip (5.27 MB)
Thank you so much, am looking forward for that statue drop simulation that uses variable viscosity.
Hey, sure - here it is: Chaos Docs
Cheers :slight_smile:
Hi
Could those sample files be saved in 2014 format please? Thank you in advance.
would it be possible to get the statue melt from the new youtube video file but for max 2016
Hey guys,
If possible, can someone from the forums help resave the scenes? We’re a bit overloaded at the moment, so we won’t get there during the next few days.
Thanks!
Hey, finally, here is the statue melting resaved for max 2015:
https://drive.google.com/open?id=1G1Qz86Nz1Tgpigg5pev_PAb-ZcrOQcDS
Cheers!
i know i asked for this before but is there any way to get it for 2016 again i cant find the file. Thank you in advance
Hey, no probs - re-uploaded it here: https://drive.google.com/open?id=1T1nYLtRhpq24UFMp7UZZyEH1ljVhdyTB
Thank you…
