i need to know settings for my scene
hii,
i am a new user to corona even not have tried it yet but will to try some. I have few images which i feel could be of more realistic level with corona.
Can anyone suggest me best settings for corona renderer for my images attached below? I am not satisfied with the quality, looking to have more realistic level and detailed work. Please tell me best settings for corona for my images and also in consideration of time factor. Also some tips for textures as well which can help better for improvement in corona.
Note: Attached images are low res renders with vray.
Thanks & Look Forward,
Corona material converter 0.19 and 7.1 corona work very good,
You can simply convert your scene materials to corona and check glosiness value,
Use environment material corona sky and 3dsmax sun (switch corona sun, dont use skylight simple check none)
Try default render settings works fine to me. just try different Exposure, Hightlight compression, contrast and
white balance value, cheers!
