RePlay,
We’re burning some frames on it now for testing, I’ll try to run a PPT over the weekend. If you have suggested settings/size, let me know.
I’m running a short animation on it at the moment. 1800 frames averaging 10sec per frame. I’ve got the same animation running on 6 - 2x2 Opteron 275’s. They are averaging 45 sec per frame. The performance seems to really depend on what you throw at it.
As for the cost, it was way below wholesale. The cost of the processors are the killer. Cheapest place I’ve seen is Monarch at $1,200 ea. I took a huge risk and purchased them on Ebay for $500ea. I was very lucky as they all checked out / passed rigorous testing.
Actual costs are as follows:
Case:
This was tough and there aren’t many options for an 8way setup. I ended up using tinkertoys for grownups and built a case with a Lubic set. It’s a little hokey but it works. I had to custom quite a bit.
Cost $110 Newegg
Plexiglass: $75 USplastics
PowerSupply, again not easy. you need 2 x 24pin & 8 x 8pin power connectors. I ended up using 2 x 850w Zippy/Emac’s
Cost $700 Antron Electronics
Motherboard S4881 & M4881
Cost: $2,426.61 Ebuyx.com
Processors: 875 6 from ebay, 2 from Monarch
Ebay: $2,981 (this is where I really saved)
Monarch: $2,028
ram: corsair 1gig x8
Cost: $1,160 Newegg
HD: 4 x WD Raptor 150
Cost: $796 Newegg
Video: XFX FX7950 GX2
Cost: $500 Newegg
Heatsinks: Cooljag. (only side flow setup I could find that would fit) BARELY!!!
Cost: $280
Fans, Misc
Cost: $100
Total around $11,000.
If you can build one for less, I highly recomend it!!
As for the rich boss, he’s not that rich and he’s me
Only reason I built it is because of the deal I found on Ebay and work as been pretty good this year. I don’t get to do much production work any more so I try and have fun where I can. Usually it’s building up new gear. Fun for me, great for the guys when they get to use it.
I’m building a new storage array now. 8Terrabytes with 1Gbs througput. Cost to build so far is 10k. Were sorting out some driver issues but when finished, it should speed up our disk access quite a bit. (especially since our current storage is barely pushing 150Mbs.)
[/list]
