Hi Guys,
I saw somewhere that now it is possible to use an ID for the Lens Flare.
Can someone share with me how to add an ID to have “Lens Flares” in just a couple of areas ?
I will appreciate any information.
Hi Guys,
Are you referring to the Lens effects enabled from the VFB2? They act as a post-render effect, which depends on the intensity of the pixels, controlled via a certain threshold, rather than through specific IDs. I’m aware of other lens effects such as the 3ds Max native ones that use IDs though.
Hi Aleksandar,
Thank you for your answer.
I understood already the way vRay5 works, but let me use my workflow and let me see if Im available to do as always I did and I will come with a result an questions for you ;)
Cheers !
