idea of how to do it ?
a make2d + a pale shader for everything on two separate layers ?
Micha would you like to do a simple small tiny tutorial on how is your setup in Renderman Air to mix it with Vray ? to do something like it ?
I never found the “ouline” stuff you were talking in AIR.
Jp
You find a chapater: toon rendering and illustration in the AIR help. You must set two basic custom commands:
Option “toon” “float maxinkwidth” 1
Attribute “toon” “float inkwidth” 1
Best you use a high pixel sample count like 12. For more infos read the AIR docu. :wink:
You have repost an image from me without outlines. :wink:
excellent,
I got to see the help file.
I didn’t see it at first.
Thank you !
