If someone is pissed it’s because he does not understand how vray calculates. Why would you be pissed because we make things more clear and understandable?
If someone prefers not to understand what he is doing and he doesn’t mind about render times he could be pissed off, yes.
But could some some people be annoyed because for years they didn’t think a render time could be lowered by increasing subdivs? Could someone be annnoyed because some settings can be changed without affecting the result at all?
there are 2 ways of seeing the problem:
A- Or we want an interface that shows the user what vray really does and the user can understand what it does and so the user has absolute control on exact number of samplings for everything and thus we can more easily get the lower render time possible for every scene. When we change a setting we know exactly what it does and can understand rapidly what we are doing at all time. But we have to understand how to balance sampling and what each type of sampling is better at (GI, glossy ref refrac, dof, mblur, shadow, or sss)
B- Or we want an interface that hides everything from the user. With some settings that try to balance samplings for us but at the same times do calculations that we can’t understand easily so if we want to really get the lower rendertime for every scene it’s almost impossible to do without being a genius like akin and being able to do some advance reverse engineering and create his own calculator. And when we discover that some scenes have unacceptable rendertime using this method we add another setting that make it more complicated. The user doesn’t need to understand how to balance sampling and what every sampler is better at, but you still need a lot of trial and error to maybe figure something that works 80% of the time.
I think we need less time to learn what’s needed to use option A than to do the trial and error that we need for option B.
And only option A allows the user to find optimal rendertime in all situations. (that, in real life, means sometimes lowering a rendrertime from 8 hours to 2 hours.)
It’s never too late to do the right thing.
