Ideas on making V-Ray's sampling UI more intuitive.
That would be in tomorrows’ builds though.
After this, Vray would basically have just one knob… noise threshold… that would define ratio between speed and quality, and other one, for advanced users, that would define ration between adaptive and more brute force approach. Of course, this is just ideal dreaming, and has quite far away from practice, when it comes to Vray.It is an admirable goal, and to be honest I have thought about some kind of automatic deduction of sampling values, but this requires research and time, which we don’t have for the 3.0 release. But there are always service packs…
For the moment, this is the best that I can do for those crying rivers for Arnold- or mental ray-style sampling.
Oh, and last one… Light cache subdivs… I know i was told that i should not use width of output resolution as a driving factor for Light Cache accuracy. But it just does not make any sense.You have looked at the example images here: Chaos Docs - do they help to clarify this?
You keep the relative detail though. If you render a large-res print, it is very unlikely that you will still want each light cache sample to still be a few pixels in size.
In general, this can be implemented in two ways: the light cache can be relative to the resolution (as it is now), or it can be in absolute pixels (like the irradiance map is now). Both ways are still valid, and you will always have to adjust one of them depending on what you want to achieve. So if we fix your specific case, we will introduce extra work for other people (those that now have to reduce the irradiance map min/max rate for large-res images).
Whichever way we chose, some users will have more work to do.
Being able to toggle the division of shading subdivs is definitely a step in the right direction. Thanks Vlado!
(I still think ‘min shading rate’ belongs down in the Global DMC section… :))
Btw, I’ve always wanted to say that… but what happened to the “artists’ time is cheaper than machine time” talk? That’s exactly what the universal set up is for…
You have access to the nightly builds, play with it and see how it goes. I still don’t think this approach makes things any simpler or easier, but I’d love to be proven wrong :slight_smile:
Recon442,
I can send to you a link for my mastering vray video that covers the fundamentals of optimising Vray (I even explain why Vray is trying to optimise things for us)
At the end of the day, VRay definitely needed that option to disable the link between Max aa and Global subdivs so thats exciting but really, Vray isn’t that hard and you are being a little melodramatic about how difficult it is. (I used to be the exact same)
I’d say it’s more a lack of detailed documentation requiring a lot of trial and error so I do feel your pain.
It only makes things easier for those who don’t know about the connection. (Which based on user feedback from my first lesson is the number one thing people misunderstood!!!)
I personally get why it was implemented but once you know what you are doing, it’s definitely annoying.
Ok, thanks for giving it a try! Let’s see if someone else has comments on that too.
Vlado, I only have access to Maya nightlies, if can you add me to the 3ds max nightlies I’ll give it a go first chance I get.
Exactly as Grant said - it’s not a super complex issue, and understand why it’s in place and have no problems with it now that I know exactly what it’s doing.
But for someone with a fresh perspective to V-Ray, it’s the number one thing that trips people up. And in my opinion, if it’s not immediately apparent to a new user, then that’s just another way of saying that it isn’t intuitive. Whenever a user raises any sampler setting, the resulting number samples should logically increase as well. If that’s not how V-Ray wants to work, then it needs to make that absolutely clear through some kind of immediate feedback to the user (like the feedback boxes in my mockup). Not to mention that there isn’t any official documentation covering the link between the Image Sampler and DMC Sampler.
I like to think I have an eye for good UI design and simplifying complex things down to their essence - and my mock-up is simply an attempt to give people either way of working that they prefer, while reducing the amount of controls to the bare minimum, and making their functionality as immediately clear as possible.
Sure, email me to vlado@chaosgroup.com and we’ll sort it out.
Recon442, just out of interest - what is ridiculous or complex on the dome light workflow?
more easy i almost cant image?
isn tit just loading the hdri and maybe raising the subdivision a bit and you are done?
I wouldn’t drag the reflection slot into the Vray environment tab, it will produce a different reflection!
Also, I always start from a preset scene so it’s always set up, simply drag a different HDR in to my dome.
All the options available are great!
Yeah, I agree - I have no problems with the Dome Light setup, other than it defaulting to 30.0 for intensity… and I’m a hardcore minimalist. :slight_smile:
No, it is not; it is on the to do list, but we didn’t have time to look into it so far.
2, In Global Illumination tab, there would be new rollout with just two things. Checkbox to enable/disable IBL, and value box for IBL samples. That is all. Checking it on would enable IBL from environment map.No, no more rollouts please, we have enough :slight_smile: But automatic dome light is on the to do list as well. This will probably remove the need for 1 altogether.
There are also other funny things like having to enable reflection environment override when you want to override just refraction environment ;)But, on the other hand, if you want to override both the reflection and the refraction at the same time, you are saved some clicks :slight_smile:
In vray 3 you can disable affect alpha inside the domelight + the resolution isn’t capped at 2048 pixel anymore. I think its more like 8k now? And you can fix the pixelated issue by putting: “$.dome_visibleOriginal=2” inside the max script listener.
There is no need for that in V-Ray 3.0 either, it’s done automatically.
Oh I did not know that. Thanks!
I was able to give the new ‘Divide Shading Samples’ checkbox a test drive yesterday, and I’ve gotta say that I’m very thankful to now have the option to control my sampling using either method.
I’m finding it effective to begin by setting all my local secondary subdivs to 1 across the board, tune the AA subdivs to what’s needed to properly resolve geo/textures/dof/moblur, and then systematically increase my local secondary subdivs as needed to eliminate noise in those specific aspects while keeping render times at a minimum. I definitely feel more in control of my scene, and like I said - it definitely feels good to have the option available.
I’ve added its functionality to the DMC Calculator as well for anyone interested.
I recently tried to understand Grant, Akin, John and Toni explanations about the dmc sampler and the first thing I wanted to do after understanding them is to make this exact request akin Just made here! But I would add a few features to the interface:
I would create a different global multiplier for each kind of noise source. and I would rename the software as “VRay Intuitive 4.00.00”! And the feedback boxes in the material and sampling areas are a must or we need to have akin claculator open at all time when using vray… Is there anyone who could make a script that open a window and shows something like akin’s calculator witht the vray settings taken from the scene and showing the resulting samples?
That way we can balance the sampling for every area and if we need more precise balancing then we go right in the mat, light etc themselves.
And the global mutliplier for the reflection and refraction could be linked to the glossiness value, lower glossines would get proportionally more subdiv.
And Vlado I don’t understand your question about where would the irradiance map and importance sampling fit into this? First can you tell us where do they fit right now? I don’t use irradiance map so I don’t know about it. And importance sampling is something vray does under the hood and I can’t find any info about that other than vray check if it’s bright or dark and put less sample in the dark area. So I guess it would just continue to work that way? Or is there a settings that influence importance sampling that we are not aware about right now?
Also about your comments saying human time is more important than machine time… I would say that in my case and the case of everyone working with a deadline, our machine time really has an influence on money income and money = human time. I mean if I miss a deadline or don’t meet quality requirements within my deadline I can loose a client and a lot of money meaning a huge human time loss…
There already are different multipliers for the different sources of noise - for each of them in fact - be it material, light etc. I’m not convinced that adding yet more parameters is a good thing that will bring any particular usefulness other than more confusion. After all, it wouldn’t really do anything more than what is possible right now. Ideally, what we should be striving towards is the exact opposite - removing any parameters that bring confusion and trying to make V-Ray as automatic as possible.
