Idle
This is how my Vanatge works 90% of the time. I launch from a live link, Vantage opens, and it sits idle. I have to turn the link on and off several times for it to work. Also, the end frame is alway 1, and not what I have set up in MAX, which is usually 900.
There could be some information logged in the maxscript listener window. It seems that the live link script doesn’t properly detect when Vantage is ready to link. Does starting Vantage in advance instead of through the live link toolbar button serve as a workaround?
I never rely on Max starting and linking to Vantage. Instead open Vantage and Start Server manually, then press the live link button in Max. Never an issue.
It has never worked for me. I have to close and open it via the MAX button several times.
Do you mean it never worked if started in advance from the start menu?
Is there any difference if you try with a small or empty scene?
