Idrop lights?
Why aren’t the lights i drag-copy from the erco site http://www.erco.com emitting the right amount of light in Vray?
works fine in lightscape though
try it with idrop, the lights have a specified “light signature”
the lights work fine for me ?
have you got design extentions for max.
you can explode an i-drop into it separate bits adjust the light then reasemble.
Natty
because lightscape has its exposure-control on by default. in max you want to turn that on manually in the environment tab. it uses the same ranges for mapping as lvs did.
-aksel
i dont think exposure-control works with vray
