So I downloaded IES gallery from Enscape website, but for some reason, it does not show up. (see attachment)
My friend tried it on the same computer (but with different company user account), then IES shows up fine.
Is there a way to fix this?
Hi @kenwhen I cannot reproduce your behavior.
Are the windows transparent?
How are the windows behaving during daytime?
Did your friend use a different windows account?
Could you compare his settings with yours?
Can you revert your settings to default settings?
Are you starting in the same 3D view?
Can you download and test one of the IES standalone executables?
Check the phasing of the windows. Enscape will sometimes render ‘existing’ windows gray and not let light pass through them. Try changing them to ‘new construction’.
@kenwhen For what process do you need the IES test project? It seems that the windows have different settings on your side.
Are you able to place IES lights in other projects and are they lighting the scene properly or are the windows transparent?
It would help as well if you could send us feedback via the [Feedback] button in the Enscape ribbon.
