ies light
Is it possible to use ies light in vfr?
are there some way to simulate this kind of lights?
thank you :slight_smile:
ies light
I don’t know when it will come - it’s not implemented yet, but I have done some tests in the past. It’s possible to simulate it: place a sphere with transparency map around a point light.
Here the link to my test post. Only full user have acess to the general forum, but here my main post as quote.
Here part two - full 180? light distributation control.
We need a point light and one sphere around. On the sphere is a lighting gradient map mapped at the transparency slot.
The sphere will cause a problem: the sphere dosn’t seems to be full closed, there is a light gap allways. To avoid this, I have placed the point light in two mapped spheres (see image), one sphere turned 180? horicontaly. If we disable the double side option of the sphere material, the spheres can be set to a diffuse color without increase the rendertime by additional indirect light.
In Photoshop we can adjust the map per gradient tool.
If somebody like, I can upload the sample scene and map.
-Micha
ies light
looks good Micha, bright idea 8)
ies light
thank you micha !!!
Re: ies light
Is there any news on this?
It was October 2006 the last time somebody posted. . . Buit I stumbled across this: http://asgvisdev.blogspot.com/
It seems to suggest that Spotlights and IES lights are now supported!? In Vray for Rhino?
I apologise if I’m missing something here. . . (Probably a plugin!?)
(I’m currently running Vray version 1.05.29 through Rhino V4.0 SR 7)
Re: ies light
We already have IES light on Rhino, but it is not fully implemented. Type in the command line “VisIESlight”. The main problem with the light is that we don’t have any way to control the brightness, but you can use an external software do reduce the intensity of the light. This is the program that I use to control or even to create your own IES light
http://www.rip3d.net/downloads/html/009.htm
Best
Re: ies light
Thanks Fernando,
Much appreciated.
