Hello, i am experiencing difficulties controlling the intensity of light and rendering ies lights. the only lights that work are the ones from the sample file, all the other lights from online manufacturers are not rendering. In addition i cannot seem to be able to dim the lights using the revit controls. if you could explain which settings are relevant for enscape light intensity calc. that would be helpfull.
I am ruining version 2.0 windows 10, revit 2017.
here is the issue.
purple lights downloaded from bim object appear “off” in enscape while the left lights are from the sample ies lights appear “on.”
this next image shows lights are on as per in view settings (rendered using raytrace view mode in revit)
