Hi there,
Apologies if this issue has been posted before - I’m having an issue with IES webs not shining upwards onto the ceiling.
Here an example - Enscape/Revit Render:
@Lewis_2 could you please share your project with us via so that we’re able to analyze it?
I don’t have an answer right now.
Sent*
No worries - Thank you
@Lewis_2 I’ve checked your IES file and can give you an exact answer now.
We currently only support symmetric hemispherical IES files.
Your IES web has some “ears” on top which aren’t symmetric/hemispherical and therefor they’re currently not displayed in Enscape.
I’ve inserted the yellow lines for better understanding. You can see the clear edge of the light in the Render window in the middle which is the exact same edge you see in Enscape. You could edit the light family and so that the “ears” are above the geometry so the edge would fit the edge of the ceiling.
But we want to optimize this in the future, for sure.
Great explanation - clears that up thank you.
