the ies lights seem to be behaving incorrectly in the new alpha 7 version. see the attached images, nothing was changed just opened the file and hit render.
Max 2014.
Guillermo Leal.
Is the light inside a rectangle or a sphere? Sphere should work
its a sphere, i just removed version 7 and tried 6 again and it works fine.
i have attached the file so you can try it as well.
Guillermo Leal.
CornellBox.rar (183 KB)
ok, I’ll take a look
This is actually a bugfix, the A6 version is working incorrectly. The IES is defined only for a hemisphere, so it should be black on the other hemisphere. This was fixed in A7, so now it renders consistently with the 3dsmax photometric lights.
Thanks for the clarification.
Guillermo Leal
