IES vs HDRI lights
Naturally i was pissed off by the render times of ies lights. So i started to fool around with them and normal lights to see if i could fake it. I setup a spot light and an ies in the same location and had the spot turned off. i only used it as a camera point to look at the image the ies light made on the ground. this i saved as an hdri then i loaded it into the projector slot of the spot light.
IES light
Spot Light Multiplyer = 1 HDRI Multiplyer = 1
Spot Light Multiplyer = 2 HDRI Multiplyer = 1
Spot Light Multiplyer = 3 HDRI Multiplyer = 5
Spot Light Multiplyer = 1 HDRI Multipley = 40
So it seems the closer you get to looking like the IES light it seems you cant escape the render time. Best solution however was to use a lower light multiplyer and higher HDRI multiplyer
wow good test …thanks
Hi Da_elf
thank s for the explanation
but could u suggest what do u mean for low value for a IES light source?
I never used them and so I don’t know wich are high and low values for this kind of sources that I remember different from standard for intensity
thanks in advance
You would need inverse square falloff for the light, if you want to model an IES light source, too.
yeah. my spot was using inverse square.
pengo…what did you mean by asking what i meant by low value for ies lights. i never said anything about low values.
