I sometimes work on scene with more thn 20 cameras.. & some time i get confused which camera rendered image is my VFB showing.. & with heavy files it is really difficult to switch to each camera to check visually.. so if it can display camera name somewhere will be nice.. or is it already available somewhr but i am not aware?
Thanks for the suggestion, will make a note for it. In the meantime, you can use the %camera keyword in the frame stamp to display this information.
Thanks for your suggestion Vlado, If i am not wrong stamp get hardcoded on the image, which means if i want to get rid of this later i must crop that part of image.. isnt it?
If you use the V-Ray VFB, the stamp is not hard-coded into the image until you save the image, so you can turn it off from the VFB UI.
