I'm in a hurry: please could help me with how to project a shadow from an objec
I’m in a hurry: please could you help me with how to project a shadow from an object which I don’t want to be seen?.
I’m using 3DSMAX.
The scene needs to place some furniture in a room which is a 2Dimage as background. But the room has a lot of cristals/windows which have frames which projects shadows over the furniture I want to place. So I decided to model approaching the frames and cristals to the 2D image in order to project “accuratelly” the shadows, but I don’t want that the model of the room can be seen: I need its shadows but I don’t want to be seen.
3DSMAX has via Object->Properties>Hide_To-Camera option which worked for me in the past, but I fear that this could be due to corona Renderer.
Would you know how to help me?.
Thanks in advance
Is that what you want? Only shadows on a transparent export - Corona for 3ds Max :: Help Required - Chaos Forum
Let me see…
I don’t know at first sight where the catcher and caster options are located…
I have never done something like that but I think it’s what I see in your render image: only the shadow and light beams…All except the geometry.
I’m gonna download your scene and see if i can achieve this result.
Thank you very much romullus. I think I have solved my problem thanks to your both materials attatched in your scene although I have to make some post-production with Photoshop but it can do the trick very well.
Kind regards.
Jose.
