Image Editor - ask to save before closing
It’d be nice to have the CIE to ask if you want to save the changes.
Thanks.
Doesn’t it already do that?
Sometimes it does, sometimes it doesn’t.
Edit: also in that message there could be a Save button. It’s pretty much what every application has.
It doesn’t ask confirmation if no changes were made. That is expected behaviour. If you ever encountered situation where you’re sure that some canges have been made, yet CIE exits without confirmation, then you should report it as a bug.
Agree on that, i think that prompt to save and conventional yes, no, cancel, would be better.
Right. I meant after making changes. I’ll see if it’s replicable and report it.
Here’s an example.
I change a setting and it doesn’t ask to save. It should ask…
Thanks for reporting this, we have it logged.. It seems to only happen when adjusting TM parameters.
Cheers,
Rowan
(Internal ID=995514241)
I had this happen a few times when changing bloom and glare, no prompt coming up.
