Image on top of foil... How do I do it?!
Hi Forum Gang!
I am currently working on some cigarette packaging and need to achieve the look of the box graphics being printed ontop of matt foil. Basically the artwork will look metallic. I have used the Layer shader with a matt gold base and can achieve to mask out areas where there is no image and gold shows through but I can’t seem to get them to mix. Any help will be much appreciated :slight_smile: John
Could you post a real life image of something similar?
I guess it would be something possible to do with a few layers of the layered mtl.
Hi Maru!
Thank you for such a quick response. Here you go…
Actually, even better! Here is the box we are working on :wink:
Hey !
Play with the layered mask to mix the strength of gold over the mate blue.
Is it something like that ?
Cigarets.zip (314 KB)
I’d try placing the color map of the image in the reflection color slot of a metallic (high fresnel, low glossiness) material.
…and dont forget to get mask of that… you can fix some highlight easily in photoshop later.
I am just finished a cigarette pack campaign.
Thank you so much guys! Have a great weekend :wink:
