Image sequence texture support from 3dsmax
does Chaos vantage support loading image sequence as texture either in bitmap or vraybitmap map?
Regards,
Yes, it’s supported.
Greetings,
Vladimir Nedev
how do I use it? I tried but it didn’t work. I loaded rendered jpeg image sequence as bitmap texture in 3dsmax scene using livelink. But it is not showing up in vantage.
ok it seems it was firewall issue. Disabling firewall worked. So how do I keep firewall on and also keep chaos vantage running? I allowed chaos vantage through firewall but still if i disable it stops. Do I need to allow in private and public both in firewall?
You should be able to add an exception for Vantage, I guess, not sure why this wouldn’t work.
Greetings,
Vladimir Nedev
Hi. Thank you for the explanation. Does this also work in Rhino and Cinema?
