Image shifting when setting Keyframes
I’m setting keyframes in Enscape. When I click the add button, the view shifts slightly. I try several times to move it back, but it then shifts again. I can’t get the shot lined up exactly as I want it. Please fix this.
Hi @jkollars66,
I’m sorry to hear about this issue.
We would need more information to fix this, in case this is happening on our latest release.
Please send us a feedback report, including the log files as seen in our article here, and add a link to this forum thread as well, so we may connect the provided data.
for visibility in the forum:
the shifting originated in movement with a Space Mouse which can controll Roll, Pitch and Yaw.
In Enscape, Roll is not an accepted movement to keep the workflow as straight forward as possible for most users.
The issue occured when the “Update Camera” button in the Enscape video editor was pressed. This resets the not accepted Roll movement to the Enscape standard movement paradigm which then results in a small visual shift.
If Roll movement is absolutely necessary, we recommend using Chaos Envision which offers full free movement along all three axis.
