Image size cap???
When I try to go larger then 8k I get either (error creating bitmap) or..it just crashes when I try to distribute the render.
Wondering If anyone has broken the 10K barer and can share how they did it ..
Image size cap???
Yep…had the same issue here. Highest I got was 8500 pixels.
Must be a limit or it may be dependent on the amount of RAM.
Either way, only way to exceed it is to do region renders and stitch together in PS.
You can use the RNR script that comes in cd2 of 3dsmax
Regards
RNR script
RNR script Is that on the training CD …can you post it to
this forum?
we have 2 and 1/2 gigs of RAM in these boxes…
but its also a 90 MB file…
OK doke…
have a great day …
any suggestions on how to set up the camera
also any suggestions on how to set up the camera …to stitch a 10 k image together …
maybe render a region
then flip it …
OK I’ll try that
vlado??
do you have a explanation for the image cap size …
it doesn’t make sense …
if I distribute a render and don’t store it int e virtual frame buffer ..I can render 10 K using FR and the scalene render…
thanks …
I can’t post the script because it’s propierty of discreet, i think. If i’m wrong and it’s a public script, i’ll post it. Anybody knows if it’s public?
from our experience the “error creating bitmap” seems to be a memory leek or something in max, because restarting max and rendering straight away seems to work most times…failing that we use blowup/region etc and just move the marquee (without changing its size) and do 2 or 3 renders
no need to post it. its on max cd2.
anyway, you are not allowed to post in on the web,
OK, only trying to help
Regards
Macro_RNR202.mcr
OK think I got it…
hmm so you cats think its a memory leek …
I get the error creating Bitmap even when I try to render region ..
OK I’m going to give this script a shot…
Hmm I don’t think this is what ya neeed…
-- Saved last Manager IP/connection type to INI file
-- Reset to last Render Mode (crop/region/view/etc) after you use the script
-- Remembered last slice settings
-- Added Include All Servers and Include Maps options
I’ve got a similar take as DP. It’s most definately a RAM issue. If you render the image once and it works. Then render again and you get the error, definately restart Max. I’ve managed to render a 10K image in one hit once. It was a miracle. I’ve got 2GB of Ram, so you shouldn’t have any trouble achieving the same with 2.5 GB.
SunnyC
I’ve got problems with this script when is sending jobs (gives an error), but if yos send the jobs with no server active (all servers stopped) the error not comes up.
Rendered a 15000 px image with this las week
How does the script work …?
I droped it in ![]()
