Images got white dot
Hi, Once I finished rendering, there are many white dot at the top. My setting is default, is it need to adjust the default setting? Anybody able to solve this problem? Thank you!
Most likely your walls single sided. You need to add some thickness to them and those white dots should disappear.
https://coronarenderer.freshdesk.com/support/solutions/articles/5000516209-i-can-see-noise-in-the-corners-of-my-scene-
HI, Thank you, problem settled
