Imapviewer
Can someone confirm if the current version of Imapviewer is compatible with 1.09?
Searched all day yesterday in the forums and didn’t come across anything. Rendered out 700 imap frames, used Eric’s script to join them and attempted a render. Using single Imaps renders o.k. Using Merged Imaps results in a fairly dark rendering. doesn’t matter if I merge 2 or 200 maps, result is the same. (only thing moving in the scene is a camera)
Was up all night trying to get this to work.
Came across a post this morning that hints at Imapviewer not being compatible with 1.09? Is this the case?
Thanks.
No, it is not compatible. I’m sure if you contact Chaos they will send you one that is. My script probably won’t work with it though.
I was afraid that was the case. If I had searched a little harder I probably could have saved myself a long night but at 3a.m. my eyes were getting a little blury.
Hopefully we can get past this project and stay in the more recent builds as we continue forward.
BTW. Your script is brilliant! Thanks for making it available!!
