Does img2tiledexr command-line allow you to pass in the DWAA compression option? If so, can it also set the quality? Didn’t see it in the docs and there’s no help on the command line. Docs I found for it:
Would also be great for the command line to support “-h” for a list of help. Thanks!
Blake
You can get all the available commands by drag and dropping the ‘vrimg2exr.exe’ in the cmd and typing -help. The DWAA compression method can be set with the ‘-compression dwaa’ command.
Oh, that’s great! In your response you listed vrimg2exr.exr, but it does seem to be the case for img2tiledexr as well. Thanks!
My bad, I guess I got mixed up. No matter, the same commands are applicable to the ‘img2tiledexr.exe’, as you already found out yourself.
