Would like to see a feature that would allow you to load only a particular layer of an existing material. For example, just load the reflection layer from an existing plastic material that way I dont lose my existing diffuse map in SketchUp. Having this feature would allow you to have a library of presets for plastics, metals, glass, fabrics, and always keep your diffuse map from SU textures.
+1 Nice thought - that would be good to have.
It looks like the vismats are also in XML format, so they should be editable like the visopt files.
But I wonder if it would need to have a “merge” option then to make this work. Because as it is currently, I think it just overwrites the material.
