Asset “Computer 41-20” in “3D Models-Accessories-Electronics & appliances” caused moving problems after being imported into a 3ds max scene, it’s a new downloading asset I just downloaded. Same with an old issue like the link following. I haven’t met this before, and I have tried other cosmos assets, no the same problem. Maybe you guys can fix this by fixing\replacing this particular model asset. Thanks!
That’s weird behaviour that I’ve noticed over decades. No idea what causes it but would love to know, out of curiosity.
If you have an object like this then undo also becomes unavailable and any objects you subsequently add to the scene will be affected.
The fix is to save the file, then restart Max and that object will be useable as normal.
Yes, I found this. Luckily, this issue is only found with that one cosmos asset only at present.
This asset has been updated. Thanks!
I have the same problem with objects moving to fast. Specially from the outdoor objects. When is this going to be fixed??? it’s really annoying!!!
