Importing from other softwares
My question is, I´m normally working with cinema 4D, I would like to export my models for example in FBX format to rhinoceros that is nice imported, then, If I get Enscape for Rhinoceros, my question is, how enscape works inside rhinoceros?.. that is, its possible to apply enscape textures to my imported FBX model, and If I have changes to do, then do it in Cinema 4D, export in FBX, and reimport to Rhino and keep my Enscape applied materials to my model?.. I mean something like lumion importing models, something like reimport… Thanks in advance… This is very important for me before get your product, because I have so many changes in my projects and need an easy way to import my Cinema 4D models, thanks in advance…
Nobody Knows?..
Its possible I explained myself wrong?..
@miguelito_2 - Your question is not 100% clear. I did a quick test using an .FBX model and switching the textures to be Material Type Enscape in Rhino worked, but as I don’t have Cinema3D installed, I can’t fully test this. Can you clarify your work flow fro me?
I see a number of threads out there talking about exporting .FBX files from Rhino to Cinema4d, but not the other way around. FBX can be a bit hit and miss in terms of textures in my experience, so .OBJ. files are your other option, although I remember that .LWO files are a a little more sophisticated in regards to textures and they work well between Rhino and Cinema 4D.
Well my question is when you have exported your FBX model into Rhino, and applied enscape textures to it, this is what you have done, is there a way to reimport this FBX model if there is changes on it keeping the applied enscape textures?.. this is the question.
Can you help me with that?..
@miguelito_2 , I do not see how that would be possible all the time. If you create new geometry, even when using Material-ID mapping, essentially you will breaking any reference one you re-import the FBX model, so you would have to create the reference again. Perhaps this article regarding Material-ID mapping in 3DSMax may help you to understand how you might start to look at setting this up however.
