When I click “submit” , IE opens a webpage with this URL https://www.chaosgroup.com/500# and with “something went wrong”.
What should be?
Anyone else?
What should be?
Anyone else?
Could you try with latest version here: https://download.chaosgroup.com/downloads/5146/vraybenchmark-standalone-107-free
Server does not accept results from some of older versions Benchmark versions now.
I’ve download and tested the 1.07 but I had the same error.
Same as before, finished the 2 benchmarks, click “submit”, IE opens the ChaosGroup login, I’ve inserted the account details I use to download the Vray softwares and then I have the “Something went wrong” page.
Do you use proxy server?
If yes - you will need to enable the Bypass proxy server for local addresses option from the LAN Settings window on IE.
If problem still persist, please send %TEMP%\V-Ray Benchmark\vraybench.out file to support@chaosgroup.com
I use proxy server and that option is on.
I think that there are other filters that block the connection.
Anyway, I’m sending you my results
Thanks!
There is a new V-Ray Next Benchmark that you could try - Download | My Chaos
Thank you. I’ll try it and I’ll check if everything it’s ok.
