When using CXR as the image output format, the entire image is saved as an uncompressed 32-bit image. In many cases this results in an astronomical file size that takes a long time to save, when most uses only require 32-bit.
It would be incredibly useful for the user to be able to define the bit depth (32 bit float, 16 bit float) and compression (ZIP, ZIPS etc.) for each render element - much like you can in the standard 3DS Max EXR setup.
Submitted on AHA Ideas (CMAX-I-21).
Just to clarify: the CXR images are not uncompressed, there is compression used.
Submitted on AHA Ideas by Marcin Miodek.
(specifically it is ZLib compression in a block of 16 scan lines, it is a part of OpenEXR format)
Thanks for the update. Are all elements stored as 32-bit then? The objective of the request is to reduce the file size whilst maintaining functionality like Cryptomatte. I appreciate that there is a need for some elements to retain the full bit depth to allow for things like large exposure adjustments, but giving the user the option to reduce these where they feel necessary would be incredibly useful.
Submitted on AHA Ideas.
Yes, they are all 32-bit. I understand the request and my previous message was not supposed to criticize it. It makes perfect sense. I will leave the next steps to Tom & Co.
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
