in additional output
Hi everyone
Why “map output selectcor” is not compatible with corona?
If I remember correctly, it was technically possible to implement this only starting with 3ds Max 2024.
I tested in both Max versions and this is not visible
In my opinion, if this feature is added to Corona maps, it will have a separate use feature
Curious to know what usage you’re expecting from that map? AFAIK, it’s not very usable outside of that quirky Substance plugin.
