I’m a beginner using V-Ray 6 for Revit for the first time and I’m trying to get the grass to not appear flat. The various videos I’ve found show a Grass & Fur option in the Appearance Manager but I see a Contour option in it’s place. Would someone be able to direct me to where I may be able to modify the grass to appear 3D, please?
Dear @chris_forsyth , hello.
Could you please share example images to be more visible what may be wrong?
Since you are seeing differences between the videos and your V-Ray UI, it may be due to different V-Ray versions.
It will be helpful to include screenshot from V-Ray > Help > About the and links to the videos that you have been watching.
I will describe the general steps:
- Fur should be created in V-Ray Asset Editor, see here
- You should assign the Fur to the chosen geometry and its assigned material in V-Ray Appearance Manager (a grey dot will appear in front of the material name if the operation succeeded), see here
- You could replace the already assigned to the chosen geometry Revit material with a V-Ray one (for example some Grass material from Chaos Cosmos), see here
Please try these steps and contact us back.
TS
