Include/Exclude List for Caustics
Status: new
An option to include/exclude objects from receiving caustics.
Calculating caustics for every light and object is often not desired, because its takes longer to render and leads to unpredicted results.
A common use for caustics in ArchVis is to have caustics in the pool. So it would be more efficient and simpler to only include the pool instead of the whole scene.
Submitted on AHA Ideas (VRAYMAX-I-122).
Hi, there is already a solution in our V-Ray object properties. Let me know if this solves the problem.
Submitted on AHA Ideas.
thanks for getting back to me! I think I may not have explained my request clearly enough.
I’m aware that it’s possible to disable caustics per object using the Object Properties, but this isn’t an ideal workflow - especially for our typical ArchViz use cases like rendering caustics only in a pool.
Right now, achieving this means:
  • Disabling receive caustics for every object in the scene except the pool
  • Disabling generate caustics for every light except the sun
This process is time-consuming and very error-prone. Any newly added geometry will receive caustics by default, and new lights might unintentionally generate caustics unless manually adjusted.
An include/exclude list for caustics would simplify things a lot. I could just add the pool and the sun to the list and not worry about the rest of the scene.
That said, I’m definitely open to alternative solutions if there’s a more efficient way to handle this.
Thanks again!
We might come up with simple caustics for that kind of cases. So there mighт be a solution, just in a different way of what you though.
AHA Ideas status: New.
Set during AHA Ideas to Discourse migration.
