Hi all
Does anyone know who I can assign an object to be included in a vrayclipper using maxscript?
thanks in advance
Neil
Hi all
thanks in advance
Neil
Hi Neil,
If you are referring to the include/exclude list, you can do so with the following script: $VRayClipper001.includelist = $
Where VRayClipper001 will be the name of your clipper, and you need to select the objects you want to include, for example:
$VRayClipper001.includelist = $Sphere001
Same goes for the exclude list, where you will have to write excludelist instead of includelist.
Keep in mind that this will override any previously placed includes/excludes.
that’s perfect, thanks so much ![]()
I’ve also cobbled together a quick VRayClipper exlude list manager you can try. A bit ugly code but should work ![]()
http://ftp.chaosgroup.com/support/ClipperExcludeListManager.ms
