Inconsistent render errors (help!)
Hi
We are rendering 2 scenes at local renderfarm, both scenes are the same they just have different cameras in them. One of them renders fine, the other we are getting errors on, below is an extract from the vraylog, can post more if needed:
[2008/Oct/12|12:33:24] Loading irradiance map from file “G:\un001\Rothchild\Scenes\081010_OFFICE\irA.vrmap”…
[2008/Oct/12|12:33:25] Irradiance map loaded successfully
[2008/Oct/12|12:33:26] 2 interpolation maps registered
[2008/Oct/12|12:33:26] Rendering interpolation maps with minRate=-3 and maxRate=0
[2008/Oct/12|12:33:26] Setting up 8 thread(s)
[2008/Oct/12|12:33:26] error: UNHANDLED EXCEPTION: Irradiance map thread
Last marker is at .\src\material.cpp, line 1746: VRayMtl::shade() {2}
V-Ray Adv 1.50.SP2 for x64
We are running really close to the deadline and would appreciate any help.
Andy
It is hard to know what is the problem without the scene; if you can send us the scene to vray@chaosgroup.com we might be able to figure out what is wrong.
Just a guess, but is irradience map precalculated? If so, has it been precalcuated for each of the camera views separatly? It almost sounds like irradience map errors out for that reason.
I have fixed the problem. Not 100% which one of the changes I made solved the issue, but I think it was down to a scene scale issue. In the end I changed the refraction of the glass from 1.52 to 1.001 and it rendered. I also optimised the scene a little more.
Thanks for your input and quick responses!
Regards
Andy
