At my office we are using enscape for sketchup to do our renderings. We’ve noticed that when two different people try and render with the same settings from the same scene there are different results, usually one view will be slightly more zoomed in. This is disrupting workflow.
Enscape 2.0.2.9 is on one machine and 2.1.1.2 is on the other. Would this be the cause of the problem, and are we going to get the same inconsistencies as we update later on down the road?
Yes, most likely the renderings will look the same if you have the same version. The changes from 2.0 to 2.1 were significantly.
@hellmanna Are you using camera synchronization? In this case the field of view is calculated from the SketchUp viewport, which is not 100% reproducable (toolbar layout, display resolution). Also make sure to set a fixed capture resolution for exact replication.
Good to know about the versions.
We are using camera synchronization. I take it that leaving that feature off will be the best way to get reproducible renders. Much appreciated.
