Hey guys,
Over the past couple of weeks I’ve come across a recurring workflow problem…
I am often creating scenes that require a 360 stereoscopic view (or several) and multiple standard camera shots. Obviously to create a stereo view you need the stereoscopic helper in the scene - however this is an issue when taking the normal still shots as it doubles the image (left/right eye).
This is a real pain and would be a lot easier to manage (via batch render etc) if the option for stereo could be switched on/off via the render settings, and then saved/loaded as a render preset.
Many thanks,
Chris
