I facing this color/light issue while using vfb and picture viewer, I have 50+ renders to do and the way to optimize this is using Takes, I do all the tone mapping ajustments and lights (using lightmix) for the final render. The problem happens when I use Takes to render all the pillows and it doesn’t pull the settings from VFB and renders as seen in the picture.
As far as I know Ican’t use VFB to render takes correct? Only PV
I’m on windows 11 latest
cinema 4d 2024 latest
Corona 11 RC3
We don’t have the changes notes between rc3 and final version this makes impossible to know if it got fixed or not. Also last response we got from you in the other tread was that it was working fine, there were not mention about loging whatsoever.
