Hi guys,
I’ve noticed that some materials in the COSMOS library appear to have an incorrect node setup for the BUMP slot when using a NORMAL map.
The correct configuration, as shown in the official CORONA manual, is displayed in the attached image.
However, I’ve found that in several COSMOS materials, the NORMAL node is connected as the final element in the chain — following the structure:
BITMAP / RANDOMIZER / TRIPLANAR / NORMAL.
It might be advisable to review and correct these configurations to ensure that COSMOS materials follow the proper node setup according to the manual.
